Articulated wall mount required for 37" lcd
Discussion in 'Home Cinema Buying & Building' started by jimbob19, Nov 13, 2004.
  1. jimbob19
    jimbob19
    Sep 5, 2002
    1,531
    Dunstable
    +47
    I have ordered an LC37GA3E and when it arrives will be mounting it in an alcove. I therefore need a mounting bracket that I can pull the screen out and angle it in to the room (no vertical movement reqd) All the brackets I can find will only take LCD's up to 30" and 20kg
    Anyone got one of these mounted this way or know a supplier of mounts for this size ?
  2. jimbob19
    jimbob19
    Sep 5, 2002
    1,531
    Dunstable
    +47
    C'mon someone must be able to recommend one :lease:
  3. jimbob19
    jimbob19
    Sep 5, 2002
    1,531
    Dunstable
    +47
    I take it no-one has a 37" LCD wall mounted then :(
  4. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
  5. jimbob19
    jimbob19
    Sep 5, 2002
    1,531
    Dunstable
    +47
    Many thanks for the input - have found the vogel ewf2003 which will do what I require but at a cost of £266 - Can't believe that these mounts cost that much , may have to improvise and see a local engineering firm
  6. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    £266! :eek: that's a serious wedge of cash for a bracket - even if it does tilt! Good luck with the improvised route. Let us know how you get on.
