this is the difficult part......but then again, reading the Lyngdorf thread it now appears people are getting different results each time they do a calibration?!?
Since they can't do the exact same calibration twice it is
possible. This has never been a new thing, but if you follow the set up rules closely then it's not a hit or miss scenario. You will get a consistent level of correction.
I’m not having a dig, but the point being, if RP is that good, why does it give different results from different calibrations? I experienced the same when I had an MP50.
Because it has an open state. It's designed to halt at 95% as most of the work, if not all is done - you can go on to do more and it
may alter the results, albeit very slightly. From all the REW measurements I did with it, the only real change came with different sub delays and speaker positions.
I've found that the perceived differences in these runs inconclusive. It's actually much more likely (where the number of measurements are the same) that it's a mere product of someone's imagination. A user recently upgraded his firmware, loaded the same calibration file and believes he has a better sound and not sure why and even acknowledges it may be in his head. The only way he could know is with very detailed before and after measurements, which he doesn't have.
Im not saying they produce bad calibrations, but they should be consistent. This is where the random mic positions will give different results I’m guessing.
Think about it like this, if they were so different and pot luck based then you'd have credible and many reports about it.
@arisholm defined room knowledge percentage effects based on the white paper and as a serial tweaker has never ended up chasing his tail on a percentage based calibration, nor have I. I think it's around 8 or 9 different mic positions and I'm done, that seems to come out 97/98% in my room.
When you give someone a percentage base and part of the story, then you get a game of Room Perfect telephone which I explain in that thread, along with why humans have unreliable hearing and how their perception of audio can change in a short period of time and for an undetermined length of time.
The way 'trained' listeners or musicians / engineers work to keep things moderately consistent is they listen for certain cues in tracks and alter those cues, they don't alter a whole track in real time, it's more of a stitch together job. The actual raw recordings of the instruments will be the same when the mic positions are - this would be the pre eq state. (your room measured without correction)
If there was a way of swapping quickly enough between the top processors after they have been set up that would provide a great comparison day which would include the benefits of the different room correction
It's possible but requires a lot of patch bays - then you have people arguing about how the patch bays are affecting the audio (even tho every studio in the world uses them)
Room Perfect does indeed yield very good consistent results, there's overwhelming testimony for it, with 2ch and multi channel. I haven't come across such testimony for movies and music on this forum, which has a large sample size.
There's also the:
'well it's good if you just want to do an easy set up and it'll be good, but if you really want the best then you need to use this other room correction'
This is absolute cobblers. The end result of the system sound should be the deciding factor, not the journey. If you want to make a Lyngdorf set up more complex, just open the voicing tool. You can make substantial changes there and noodle away all day. I haven't personally yet heard any system where the amount of 'things' it had was a correlation to how good it sounded and I'm including the Accurus with PEQ only in this.
Am I interested in this comparison test?... not really. I find it easier to listen to the systems multiple times with similar source material, that's all I really need. It's not all just room correction either. It's not hard to tell the difference between my system and a Steinway Lyngdorf one, which is quite stark - so deployment must be considered too.
