This is a useful article on Room Perfect, thank-you for taking the time to walk through the details of what it is and what it does.
Agree with
@Apollo that it would also be great to get views on how the various other room calibration system compare to Room Perfect and each other e.g. YPAO, ARC Genesis, Dirac and Room Perfect are four systems I've heard of.
My experience using YPAO some years ago with a Yamaha 3060 AVR and most recently using Room Perfect has been that both were reasonably straightforward in their setup out the box, whereas Dirac felt like something that potentially is better getting some training on or perhaps getting a calibrator in to setup to get the best results?
In terms of Room Perfect itself, all I can say is how easy it has been to get some truly fantastic results. As a system, it is very easy to recommend for those that want something that 'just works' and don't have the time / or know how to get a calibration with the best results with little effort.
When I tried using Dirac over the last year or so, I really struggled as I was never quite sure if it had been setup 'properly' (in terms of how to apply / use various harman or nad 'curves', how best to adjust the peaks and troughs (believe the approach having spoken to Arcam is to try and get a mid point between the curve and the speaker response) or how much to best apply with the 'curtain's - some folk advised focussing upto 500 hz, other's advised full range, etc.
Does anyone have a view on how much impact background noise (e.g. road noise) can have with Room Perfect (and other room calibration systems)? Are they able to identify/ ignore the noise, etc or is it best doing calibrations late at night when it's quieter?
