Artcoustic Speakers?
Discussion in 'Home Cinema Speakers' started by Xstyle, Nov 23, 2004.
  1. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    I have just come across these speakers:
    http://www.artcoustic.com/products.htm
    The Artcoustic Multi can be used as centre and left and right... and looks awesome!
    but it is £1300!
    The Artcoustic Diablo Monitors can used as rears ... and are £1000 for the pair.
    BUT the benefit I like with this is that you can put your own picture on them at £80 each! ...removes the need for any other artwork or whatever on your walls.
    (Ouch!!! ...when you write it down you can see how much speakers alone are costing!)
    Hmmmm...........
    Do I need front L and R, or will the Artcoustic Multi just do?
    (and pair of Diablo's at rear ... maybe 3 at rear??)
    Multi:
    http://www.artcoustic.com/download/DF-Multi.pdf
    Diablo:
    http://www.artcoustic.com/download/Diablo Monitor.pdf
    whats your thoughts on their performance???
    Thanks,
    Sid
  2. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    The dealer said the Multi by itself on the front would not be enough, as its ideal for upto 7ft away. My audience will be around 10ft away from the screen & front speakers.
    So they suggested going for the Diablo C1:
    http://www.artcoustic.com/download/Diablo C-1.pdf
    and then the 4 x Diablo Monitors all round (2 front and 2 back).
    However this C1 is not as long as the Multi which is the same length as the plasma ...
    I want everything to be in proportion and look good on the eye.
    Another option is the Artison Portraits? (£1300)
    http://www.futurehome.co.uk/scripts/prodView.asp?idproduct=230
    Left & Right only ...so wouldn't need a centre speaker....
    thinking of aethestics!!
  3. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    I have found the answer I was looking for by contacting Artcoustics direct, in the UK!
    After much searching:
    http://www.productselector.co.uk/sitemap/..\Docs\1\20641\external\cov.htm
    Artcoustic Loudspeakers
    Studio 6
    Pickwick House
    20 Ebenezer Street
    London
    N1 7NP
    Tel: 0207490 7202
    Fax: 0207490 0526
    Web: www.artcoustic.com
    Email: artcoustic@artcoustic.com
    They say the DF Multi is more than enough for a small room like mine.
    4m away from the speaker is great. Just what they have in their showroom.
  4. dts_boy
    dts_boy
    Nov 26, 2001
    2,536
    Manchester suburbs...
    +141
    don't forget to budget for a sub as the smaller ones don't really do bass. i listened to the bigger 65-50s earlier this year and they were awesome but in the end bought something else as i couldn't mount the L&R on the wall
  5. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
  6. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    Will prob end up getting the BK xls200...
    DOES ANYBODY KNOW WHERE ARTCOUSTIC GET THE ARTWORK PRINTED ONTO THEIR SPEAKER CLOTH ??
  7. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    Denmark
  8. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    Basically I want the Diablo's Mini's, but Artcoustic do not do the Design service on them.... (says they are too small ... but they aren't, as they are almost an A4 page in size!)
    http://www.artcoustic.com/download/Diablo Mini.pdf
    I'd be happy to send my speaker cloths off to Denmark!!
    Exact printer company details?? .....longshot!
  9. Xboxing
    Xboxing
    what did you go for in the end?
  10. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    I "had" bought the DF Multi for £500 from Pounds TV, 2nd hand from Frank Skinner with 12 months warranty, however they now say the £117 deposit I paid was for an install quote not the speaker, which is not how they said it at the time.
    They've sold the speaker, and I feel totally ripped off now.
    Plus their install quote is ludricously higher than others!!
    :mad:
