EndlessWaves said:
Nonsense, spyware is installed secretly without the user's permission. Apple had already given implicit permission by allowing any programs to be installed on those systems and he even went and got explicit permission from an employee. He didn't install it secretly either, but sat down in front of the machines and did it.
He asked an employee if it was ok to take photographs in the store and was told "yes" and because there were no signs saying "you are not allowed to install software on these machines" he assumed it must be ok.
At no point did he ask an employee "can I install a piece of software on every machine in the store that will secretly photograph customers and then upload those photographs to a server for use in an 'art' project I'm compiling?"
If he had I would wager a significant amount of money that the answer would have been "no".
Using your logic if someone was at your house and they started playing with the configuration of your computer or rearranging the contents of your fridge it would be ok because you hadn't told them they couldn't do it?
