Arrrgghhh! Can't get winamp radio to work!
Discussion in 'Desktop & Laptop Computers Forum' started by nathan_silly, May 28, 2003.
  1. nathan_silly
    nathan_silly
    I've reinstalled windows drivers, uninstalled winamp 3, then reinstalled winamp...winamp plays mp3's ok but when I select a radio station winamp opens but nothing happens.
    Adding the .pls manually to the playlist works... but it used to work fine..
    heeelllllpppp!:D
    [10 seconds after posting this thread]
    huuuuhh? It's just started to work!
    Computers eh?:rotfl:
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi Nathan,
    Yep i've had this problem before as well..............
    Select options / preferences and select the media tab, you should have a grey button that says 'all', press this and all should then be ok ??
    It's worked for me, so it should be fine.
    Cosmic023
