Arkon car mount + XDA IIi
Discussion in 'Mobile Phones Forum' started by Gadget Daddy, Aug 19, 2005.
  1. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,281
    83
    Stockton on Tees
    +185
    Ive got an Arkon active powered car mount for my IPAQ H5550 and was trying my XDA IIi in it as the connections appear to be exactly the same.....but no joy no output to speaker or indication that it was charging, so it appears that possibly I dont need a new Arkon mount but possibly just a data / power cable which I think is this cable below
    http://www.expansys.com/product.asp?code=115795
    But at £7.50 seems a bit pricey for what it is, so 2 questions really if anyone has had any similar experience....do you need a new Arkon mount for different devices or can I get away with just the data / power cable, if the later can you get it cheaper than the link above.
    Any help gratefully received.
    Pete
