ariston turntable
Discussion in 'Hi-Fi Stereo Systems & Separates' started by ianlecompte, Jan 12, 2005.
  1. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    just discovered my t.table is an ariston transcription made in 87.does anyone know anything about this deck,bought it eight years ago for £40,but only recently started to use it,it appears to have a fairly good tonearm,cart i,m not sure about prob the original.i,m using an audio tech stylus.it doesnt sound as good as i expect though,the sounds very weedy sometimes and has no real depth.keep checking for the obvious like tracking,quality of styli etc.,do you think a cart upgrade would help,or should i consider an upgraded deck? any thoughts would be good.
    cheers
    ian
  2. Beobloke
    Beobloke
    Aug 10, 2004
    1,312
    Out in the Sticks!
    +65
    Do you know the model number? What about the arm?
    Ariston made some very fine transcription turntbles and quite a few came without an arm, leaving you to fit your own, so it would be difficult to recommend a new cartridge without knowing what the arm is.
    A photo would do if there's no obvious markings - i'm sure someone here will be able to identify it!
    Adam.
  3. la gran siete
    la gran siete
    Oct 5, 2003
    24,774
    Deep in the bowels of sussex where the angloargies
    +1,767
    Funny I thought they made washing machines
  4. Beobloke
    Beobloke
    Aug 10, 2004
    1,312
    Out in the Sticks!
    +65
    They did, and dishwashers too - some of which were actually made by Zanussi.
    Crikey - maybe Hotpoint or Indesit made the turntables for them?? :eek:
    Adam.
