Argh! Disc stuck in drive.
Spudhead
Just got my intel 520 sad this morning, it comes with one of those stupid mini discs that you have to insert, popped it into the disc drive on my MBP and nothing happened, disc drive didnt spin up or anything. Im guessing its too small to be recognised or something like that?
Anyways tried pressing the eject button and nothings happening? Whats the best way to get it out?
Cheers,
Spudhead
Edit: Just tried the terminal command.
drutil eject
Still nothing, disc drive makes the noise like its ejecting something but nothing happening.
Spudhead
Solved it.
Anyone else in this same situation in the future, note down this useful tip. Get yourself a credit card, but some double sided sticky tape on one side.
Got to terminal, type 'drutil eject'
Get your credit card ready, hit the enter button and as the drive starts to eject put the credit card in and stick it to the disc then just simply pull it out.
P.s. intel why do you use sucky mini discs/cd's?
bpsmith
I didn't want to post that but, I agree, I would never contemplate using one of those small discs unless I had an ejectable drawer with the drive centre to physically stick it on. Slot loading is a definite no. I usually just download the up to date Apps and Drivers from the web anyway.
dante01
Alternatively, if you ever get your credit card stuck in the drive then you can attach some sticky tape to a compact disc and use this to retrieve your credit card with :lesson::smashin:
Spudhead
Well seen's as Ive used my disc drive less than a handful of times since owning it, I never knew that. Also never used a mini disc before. So sorry we're not all as knowledgeable as you guys!
D
Deleted member 27989
Glad you got it out, I'd imagine it was a panic moment :)
Ps in osx you don't need any drivers for the disk anyway :)
Spudhead
Yeah, especially because if I had to take it to the nearest Apple store for them to remove its a 2 hour car journey! So crapped my pants a tad.
Yeah it was a toolbox thing intel supply for optimizing the SSD, so tried downloading it from intel's website after I got the disc removed and it turns out its not even available for OSX anyways. :facepalm:
This SSD is phenomenal though. Power button to desktop - 12 seconds. Getting around 300mbs write and 505mbs read. :D
