Arggh HELP ME - M&K speaker needs repairing
Discussion in 'Home Cinema Speakers' started by ajbird, Jul 12, 2004.
  1. ajbird
    ajbird
    Apr 30, 2002
    105
    16
    Laceby - NE Lincs
    OK one of my beautiful M&K s85 has developed a buzz! What do I do? Where can I get it fixed? Only had it 2 years - sob sob Got them for sevenoaks in hull.. anyone know if they do repairs? or is there someone people can recommend. Cant believe it has happened - i thought they were indestructable - gutted
    cheers
    andy
  2. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    Check out the M&K web site and get in touch with Gecko.....
    They will prob tell you to take them back to your dealer, but it should not cost you anythink as they come with a 10 year warranty.
