DodgeTheViper
- Joined
- Oct 23, 2001
- Messages
- 29,972
- Reaction score
- 18,931
- Points
- 7,947
- Location
- Inbetween Upgrades !
Sub 3’s
I’m looking to do a slight change to the layout of my room, along the front.
It’s going to mean another Anti-Mode run and another ARC calibration. Nooooooo
Do you find significant difference in running anti-mode alongside ARC ? Thought ARC, Audyseey XT32 was good enough to run without anti-mode, or i'm wrong?
Yes. It helps considerably in smoothing out the response even further pre the AVR’s EQ. In this case, Anthem ARC. At least it doesn’t throw a duvet over the subs.
Do you run it after or before ARC calibration ? And which antimode do you use ?
Before.
I’ve got the 8033 SII
Ok, thank you. I dont want to hijack this thread to much any chance to talk privately ?
Sub 3’s
Try harderI just can’t quite get 4 of them in . . . . . . Yet.
Duo stacks with monitors on stands
I still love the fact you are now running a pair of large dual driver subwoofers. A few years ago most people on these forums shuddered at the sight of these kinds of things, and its awesome to see people now realising what these kinds of subs are capable of.No room to stack unfortunately.
And I think Dual Subwoofer 3’s is plenty enough
I’m considering a slight change to the front layout of my system. Thinking of moving each of the Sub 3’s toward the AV rack, so pushing them more toward the centre and each other. Then putting the Monitors onto the official stands.
Thoughts anyone ?
Would that mean putting the monitors closer to the corners to make it all fit?
I seem to remember that your frequency response looks pretty darn good as it is, so you're just looking for a change?
I miss my Sub 3's.
I'd go the other way. Subs nearer the side walls, Monitors on the inside of the Subs. Gives the Monitors a bit more breathing space away from the walls.
Can’t do that because of the screen.
The Sub 3’s just fit under the screen nicely.
Of course the other alternative is to leave it all alone
