Are you using a ceiling mount?
Discussion in 'Projectors, Screens & Video Processors' started by mi_july, Nov 6, 2004.
Mounts
Poll closed Nov 16, 2004.
  1. Ceiling mounted
    25 vote(s)
    71.4%
  2. errr not?
    10 vote(s)
    28.6%
  1. mi_july
    mi_july
    just as the name says, if possible tell us what mount etc.
  2. smerkderk
    smerkderk
    Oct 15, 2004
    44
    Berko
    Not currently using a ceiling mount but will be converting over the next month or so.
    Ask again in Jan, hehehe
  3. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,140
    Surrey. UK.
    +1,953
    I'm using a DIY mount which you can see here:
    http://uk.geocities.com/g.lightfoot@btinternet.com/ht1000.html?
    Scroll down to the current MKII version. Only cost £12, and can be easily modded by using a part from the other mount (two in a box) and a loger bolt so that you have full range of motion.
    I've also got a flush mount that will put a pj less than an inch from the ceiling, and it uses just two pieces of 6mm mdf. I'll hopefully get round to uploding the pics one day.
    Gary.
  4. zAndy1
    zAndy1
    Nov 26, 2002
    19,357
    2
    5
    163
    +6,479
    Using an LMP mount which I have to say is bloody brilliant! Looks great, fantastic build quality, thoroughly recommended.
    Andy
  5. Klippie
    Klippie
    Dec 1, 2002
    623
    Scotland
    +55
    My Hs10's up there with a diy mount here's a pic...
    [​IMG]
    Klippie.
  6. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,000
    48
    Reading, Berkshire
    +54
    Wow, great looking mount Klippie, how did you make it?
  7. Klippie
    Klippie
    Dec 1, 2002
    623
    Scotland
    +55
    Thanks SeaneyC,
    I based my mount on ceiling fan which uses a plastic ball to make it hang level. I modified the design for projector use to give two plane adjustment for perfect projector to screen alignement without using a more complicated two linkage type affair which I dont think looks as tidy.
    The mount is made from aluminium as you can see, I have a few machine tools at home i.e. pillar drill, lathe and milling machine so the various parts were easy to make.
    Its getting on for two years old now and is still doing a great job of stopping my projector from crashing to the ground. :thumbsup:
    Klippie.
