tebbo65
Hi all,
I am after opinions about introducing wide speakers into a 7.1.4 system, basically is it worth it? I have read various points about them which may or may not be accurate listed below. Comments on these points for accuracy would be appreciated.
For info, although I have the speakers available I'm not going to swap out my AVC just for wides but may be a consideration when/if I upgrade. Only really concerned about one main listening position.
- Although wides fill the gap between the L&R and side surrounds this is only really beneficial for multiple seating whereas I'm only really bothered about a single LP.
- Wides can/do make the front stage sound bigger more authoritative but only by matrixing signal from the L&R.
- Dolby Surround upmixer does NOT upmix to wides.
- New versions of Dolby are going to utilise wides more. But when & how?
- DTS X Pro will use wides but DTS X and Neural are limited to 7.1.4 (issues with DTS X Pro being implemented).
- Very few Atmos soundtracks have wide channel signal in the mix.
