Are this cables good?
Discussion in 'Cables & Switches' started by PC_112, Jun 4, 2005.
  1. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Hello,
    The Home Cinema I am about to install includes the Sanyo Z3 and the KEF 2005.2 (Eggs).
    For component and S-video I was suggested the following cable:
    http://www.hificables.co.uk/ProductDetails/mcs/productID/10876/groupID/713/categoryID/2441/v/
    (IXOS 110AV)
    For my set-top-box:
    http://www.hificables.co.uk/ProductDetails/mcs/productID/10976/groupID/711/categoryID/2399/v/
    (IXOS XHD408)
    For my DVD sound:
    (IXOS XHD308)
    And for the speaker sats:
    http://www.hificables.co.uk/ProductDetails/mcs/ProductID/11251/GroupID/710/CategoryID/2393/v/
    (QED Silver Micro)
    In the description of silver micro it is written:
    Does this mean this cable is not good enough for the front speakers?
    Thanks.
  2. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Anybody can help with this? I have to answer tomorrow if this cables are ok or not. I mostly worry about the speaker cable.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    The speaker cable will work just fine, they're just suggesting that as it's comparatively small (hence being "Micro") the cable is unobtrusive so particularly suited to running the length of a room without drawing attention to itself.
    IXOS stuff is usually well made so I'm certain it will all be just fine. :)
