Are thin sub cables much cop?
Discussion in 'Cables & Switches' started by MS-Yam, Nov 18, 2004.
  1. MS-Yam
    MS-Yam
    Aug 12, 2004
    235
    16
    I could do with a sub cable thinner than the one I use. Ideally it will be around 3-4mm thick. This is so I can position my sub somewhere other than right next to my TV/AV rack. But it needs to go under the carpet, around the edge of the room.
    At the same time though, I dont want to sacrifice the performance of my sub by getting a thin cable. The one I use is a thick dedicated sub cable from Profigold, which is great.
    Can anyone recommend any thin cables with decent performance? I think QED may do one but not sure.
    cheers guys
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If it's a powered sub, then it doesn't need to be anything special. It's only a low level audio signal. My cable is only about 3mm thick, and it works fine.
