Are they both the same?
Discussion in 'Plasma TVs Forum' started by Skiny, Sep 12, 2004.
  1. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    Would there be any difference between a VGA and a DVI cable, when connecting a PC to a plasma screen? I know the DVI cable will give a slightly sharper, and more stable image when connected to and LCD, but is the same true for plasma?
    Skiny
  2. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    My understanding of VGA v DVI (cables) is that the signal squirted down a VGA cable is purely analogue whereas the signal squirted down a DVI cable can be analogue *OR* digital - in the latter case then there should be no tuning of display timings needed to ensure a sharp image (whereas from a VGA feed your display needs to be "tuned" - usually automatically - to the exact pixel timings of your graphics card).
    Since both plasma and LCD screens are discrete pixel based devices then both should benefit from a DVI-D feed over a DVI-A or VGA feed but whether you'd notice the difference is another matter.
    Phil
  3. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    Ok, thanks.
  4. zygote
    zygote
    The picture quality through DVI is infinately better than VGA for computer signals. Before I returned my El Cheapo plasma (awaiting delivery of a PWD6) I had my PC fed into both VGA and DVI and the VGA signal was noticably more noisy and had a greater tendancy to bleed, whereas the picture through DVI was absolutely pin sharp and solid.
    HTH
