are these speakers worth buying for home cinema with no space?
Discussion in 'Home Cinema Speakers' started by evilash, Aug 18, 2004.
  1. evilash
    evilash
    Dec 11, 2002
    783
    brighton
    +6
    Wharfedale PP-S1 LoudPanel Flat NXT Speaker System
    http://www.hifibitz.co.uk/product.asp?id=1936&aid=60208
    i am thinking of buying the above flat speakers cos i am pushed for space. thing is does anyone know whether they are any good for films as i wouldnt be needing them musically + are they in fact any good at all. i was thinking of buying 2 sets and incorporating them into my existing setup but keeping my existing centre speaker.. any help very welcome... thanks hopefully in advance...
    jay
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    as rears, should be fine, i wouldnt use them as fronts tho mate, (you do know they have a bass unit, dont you)
  3. evilash
    evilash
    Dec 11, 2002
    783
    brighton
    +6
    hornydragon: at the risk of sounding speaker illiterate, i take it by bass unit, you mean the sub. if so, i was gonna route the speakers through my denon amp and use my kef sub instead....
    p.s. thanks for replying...
    jay
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    nope they will blow up straight away if do that mate, have to use their sub just like BOSE accoustimass speakers.
  5. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
  6. evilash
    evilash
    Dec 11, 2002
    783
    brighton
    +6
    hornydragon - thanks for clearing that up... is it possible to incorporate the bass unit into my setup. i was hoping to use four of them for the rears but havent a clue whether or not they can be routed through the denon avca11sr amp?
    Dfour - thanks for the heads up but am trying to be a cheapskate. :blush: i have spent what i feel is fortunes on my gear and am trying to be more careful financially as i have loads of cables and equipment lying around as it is that can do the job. e.g. linn keosa floorstanders which are collecting dust cos i aint got enough room for em at the mo. i am looking to stick four flat panels on my rear wall so as not to take up space either on stands on the floor or more space than necessary on the walls. it's the damn advert at the top right that got me thinking maybe for less than a ton, i could have some reasonable rears that look pleasing aesthetically as well as do the job they are meant for (probably not Home Cinema mind).
    thanks for the link mind. they do look nice....
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yeah the high level connections from amp go to the bass unit, wiring them is easy but it is 2 extra boxes!
