Are there different makes of Sky+160 boxes?
Discussion in 'Sky Digital TV Forum' started by crackles, Mar 18, 2006.
  1. crackles
    crackles
    Hi All,
    I've just arranged the £65 upgrade for my sky to a Sky+160 box. It looks like there are several boxes out there (Amstrad/Pace/others??) I don't know if I will get a choice or not but is there anything I should be aware of when the chap comes out next week? It sounds like, for example, the Amstrad one is a clicky noisy thing! Any advice would be appreciated!
    Crackles
  2. voyagerweb
    voyagerweb
    Jan 30, 2006
    24
    3
    UK
    well if you have upgraded to sky + 160 the only box you will get is a Thomson.
    If you have upgraded to sky + then you may get Amstrad, Thomson or Pace, try and get one of the last two by asking the engineer.
  3. crackles
    crackles
    Cheers Voyagerweb,
    I guess my choice is a Thompson, or a Thompson then :)
    Life is made so much easier when others make complex decisions for you, eh?! :thumbsup:
    Cracks
  4. voyagerweb
    voyagerweb
    Jan 30, 2006
    24
    3
    UK
    If this person has gone for the actual PVR 160 and not the PVR3 standard then there will be no choice but Thomson.
    It seems to me though for £65 i would be suspicious it was only the standard version which does have a 160GB hard drive, but only 80GB Personal and 80GB reserved for future use.
