Are there any hifi (2.1) speakers that are good with speech and music ?
Discussion in 'What Speakers Should I Buy?' started by stonyb, Jan 7, 2012.
  1. stonyb
    stonyb
    Jul 7, 2008
    35
    I am having great difficulty finding hifi 2.1 speakers that are very good with both speech (radio/TV) and music (classical).
    Have auditioned several speakers including the Spendor SA1 which was quite good with speech, but with music they could get a little bright/harsh with upper register female vocals, also the lower bass frequencies are missing - not surprising given their small size.
    Its a very tall order but if anyone has suggestions as to a very musical speaker which is equally good with speech I would be pleased to hear.
    My amp is Arcam 9. My room means that speakers have to be very close to both back and side walls - so rear ported spkrs are not on and bass heavy ones are also not suitable.
    I would prefer stand-mounts if poss.but.........
    Budget is c £ 1.5 -2.0 K
  2. Jules
    Jules
    Oct 11, 2000
    5,613
    134
    +1,092
    I always believe a speakers midrange is the key here, and from my experience Kef speakers always do well with midrange.
    I'm a big fan of Kef's uni-Q driver (as found in the Q series and above) where the tweeter sits in the middle of the bass driver. This arrangement in itself seams to lend itself well to consistent vocal performance.
    Check out Kef Q300.
    Other speakers I can vouch for their great mid range performance include Mordaunt Short Mezzo.
  3. BlueWizard
    BlueWizard
    Jun 19, 2007
    21,333
    +3,953
    I can't say whether the Kef Uni-Q are especially good in this area, but midrange is certainly the key.
    Bass can give weight to a speakers sound, and crisp treble can give a real sense of presence to the music, but for voice, clarity and detail in the midrange makes all the difference.
    If you have a chance, as well as the Kef speakers, try to listen to some Focal 700 series or 800 series. These are not cheap speakers, but the detail and clarity are stunning, and in my view, from a couple of auditions, the midrange is very present.
    Myself, though you may have a specific need for it, I would prefer to put the considerable cost of a Subwoofer into my front speakers.
    In your price range, consider -
    Focal 836 - Google Search
    Dali Ikon 6 - Google Search
    or
    Dali Ikon 7 - Google Search
    The Dali Ikon 7 is just the Dali Ikon 6 in a larger cabinet with the addition of a dedicated midrange speaker.
    You do present something of a dilemma though. Though I'm not a big female vocalist fan, that is one of the most difficult things to reproduce. I've heard some speakers that sound stunning in every respect, but they were like ice picks in my ears for powerful female vocalists.
    Though well below your budget, you might also want to give a listen to the Monitor Audio Silver RX8 speakers. Recently someone auditioned the RX6 vs the larger RX8 and though there was a world of difference, and that the RX8 stood well above the very similar RX6.
    Over your budget (£2300/pr), but the Monitor Audio Gold GX200 might serve you.
    Having auditioned the Focal 836 twice, I can say I was blown away by the stunning clarity and detail of these speakers. The bass especially was rendered to perfection. For the first time in listening to a speaker, I heard Bass Guitar in intimate detail as opposed to just generic bass.
    But again, for the clarity of voice, you want detail and presence in the midrange.
    Steve/bluewizard
  4. stonyb
    stonyb
    Jul 7, 2008
    35
    BlueWizard: - Thanks for your thoughts. I've not thought about Focals since the local stockist disappeared, but I will follow up your suggestion. So far my auditioning has been Spendor SA1 and 3, and ProAc Response D2 and D18 - all very good speakers in their way but not quite the combination I'm seeking although the ProAc D18 seem the best combination up till now.
    My existing speakers are venerable 3 way Radford Tristars (similar sound I understand to the Spendor BC1)- open, very musical with a super midrange for orchestral and classical music vocals, but a little uncontrolled in the bass and not good with speech harmonics - .
  5. eaglemmoomin
    eaglemmoomin
    Jul 12, 2007
    2,395
    63
    Crawley
    +226
    If Spendor is not quite there then you could try Neat Motive 2se/Motive 1 or perhaps Neat Petite SX (stand mount), Neat Elite SX or Neat Momentum 3 (stand mount).
  6. Mr Andy
    Mr Andy
    Jul 16, 2009
    516
    Nottingham
    +24
    I have Tannoy speakers with the same layout and like them. The floor standers seemed to sound a bit better then some if I wasn't in the ideal position. I figured this would be handy for the centre speaker as it's lower then the left and right (I hope that makes sense)
