Are there any good Denon prog scan players?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Captain chaos, Jul 20, 2003.
  1. Captain chaos
    Captain chaos
    I would like a Denon DVD player to go with my Denon amp and Panasonic A300, but I have heard good and bad things about the 2800 MkII and the 2900.
    Which is the better player?
    Do they both do PAL and NTSC prog scan?
    Are both available in multi-region?
    Are there any problems of any kind with these players?
    Many thanks,
    CC
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Many people have reported of a variety of problems with both players. Most notably problems with playback & disc reading after firmware upgrades for Multi-Regioning & PAL Progressive.
    The DVD2900 does PAL Progressive from the box aswell as NTSC progressive, but it isn't multi-region (and the update causes some problems aparently).
    The DVD2800MKII has the capacity for PAL Progressive & NTSC Progressive aswell as multi-regioning, but there's been countless complaints about the player having a variety of problems when people have tried to update firmware.
    The answers are - unfortunately for Denon Fans - quite simple. If you want PAL Progressive buy the DVD2900. If you want NTSC Progressive buy the DVD2800MKII. If you want both & aren't willing to take the risk of either player botching after updates, then don't buy either of them - stick with a player that can be remote hacked for progressive updates & multiregioning - such as the Philips DVD963SA.
    I own the DVD2800MKII which I got for £360 from Superfi, and I haven't touched the firmware & I'm more than happy with it.
  3. Captain chaos
    Captain chaos
    So why is the 2800MkII better for NTSC?
    I have mostly region 1 disks.
    What exactly are the problems with the 2800MkII?
    What about the 3800? Is that a good player?
    Im looking at spending up to about £700-800 on the DVD player.
  4. patot
    patot
    I own a Denon 2900. It is both PAL / NTSC progressive, and multi region. I have had no problems at all.
    First: upgrade firmware (see recent patot post here at this forum) - a simple copy of a file onto a CD. Then play the file. Put the machine off at the end of the sequence, and on again, from the main power button (not the remote).
    Second: follow instructions (also posted on this forum a couple of week ago) to regain PAL prog, IF lost. Some people have lost the PAL prog when going multiregion, but this is easily solved with a simple set of front button sequences.
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I have a 3800 (PAL prog & Multi Region supplied) & am very pleased with it.
    You may find them hard to find now though ;)
  6. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    Unfortuneatly Denon seems to be one of those companies that has endless problems with there dvd players, and the longer their out from the product release date, the more problems seem to creep up.
    If your main bulk of dvd's are R1 and you intent to keep it that way then just could still consider a ntsc prog scan player only. There are truck loads out there and most have none of the constant problems of nearly all the Denons', if not, all of them.
    good luck.
    Remember all your kit doesn't have to look the same to be great, and theres no such thing from a company called customer loyalty!
  7. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,203
    n/a
    +289
    :hiya:
    All the denon's that are now sold in Nexnix do not have the pal prog scan problems ;)
    dvd :cool:
  8. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Captain Chaos - it's not that the DVD2800MKII is 'better' with NTSC, it's just that if it's only NTSC with R1 discs for progressive that you're after the 2800mkII is around £300 less expensive than the DVD2900.
    If you want endless reels of the problems with the DVD2800MKII do a forum search.
  9. Richard Harnwell
    Richard Harnwell
    Sep 17, 2000
    315
    Colchester, Essex
    +4
    Ahh - so all us disappointed 2800 MK II owners (there's a lot of us...) just have to find out where to get the firmware that Nexnix use!
    Any ideas?
  10. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Maybe try contacting them?
  11. Richard Harnwell
    Richard Harnwell
    Sep 17, 2000
    315
    Colchester, Essex
    +4
    Yep, already sent an email off. I'll reply to this thread if I get anything hopeful.
  12. Richard Harnwell
    Richard Harnwell
    Sep 17, 2000
    315
    Colchester, Essex
    +4
    A reply already!
    I hope he's right......
  13. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Well Denon emailed me to say that they're "working on it" a few weeks back and that as soon as they've finished "it" they'll make it available to all DVD2800MKII owners - didn't say how.
  14. Captain chaos
    Captain chaos
    Why all this bother?
    Why don't Denon just supply all their units multi-region as standard?
  15. patot
    patot
  16. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Captain Chaos - it's because Denon are required to release their players with specification that meets the requirements of the DVD Forum.
    Since PAL Prog has now been ratified that's why the 2900 has it. If it had been sorted earlier they'd have released the 2800MKII with PAL Prog.
    It's required by the DVD forum that the Denon players released pre-pal prog are supplied by Denon as R2 and on NTSC Progressive. The Denon DVD2800MKII has been discontinued so there's no chance of a 'new PAL Prog ready' batch.
    I wont be touching my firmware until Denon have the official update ready for all users.
  17. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    +77
    Captain Chaos,
    The basic moral of the story here is... If you want constant hassle from your dvd player with repetitive calls to your dealer, then buy a Denon.
    Else buy a player that you don't constantly hear about having problems on this forum IMVOHAVOHO. :lesson:
  18. Dom Rice
    Dom Rice
    Does anyone know if the firmware for the PAL Progressive and Region Free for the Denon 2800II (from afdigitale) works. Or does it cause more problems?:confused:
  19. patot
    patot
    I live in Italy and regularly read the AF Digitale magazine. They post stuff on their web that has worked in their reviews. They are a reliable and serious source. I have not tried this firmware, but have used other stuff (firmware) on their site and have had no problems.
    I am not sure, however, if there are any hardware differences between products sold in Italy and other places in Europe, but I would presume not.
  20. Richard Harnwell
    Richard Harnwell
    Sep 17, 2000
    315
    Colchester, Essex
    +4
    I downloaded firmware from the afdigitale site some months ago. Unfortunately it is one of the versions that has all the problems (lip-synch, tearing).
  21. Dom Rice
    Dom Rice
    Thanks for the information. I'll wait until there is a relaible fimrware source without problems.
    Ta.
