Are there any difference between integrated Soundcard and seperate PRO one?
Discussion in 'Computer Components' started by rmask, Aug 25, 2005.
  1. rmask
    rmask
    Mar 25, 2005
    115
    +4
    your thoughts on subject
    Currently building my new pc
    and I'm not sure if I need better card (integrated alc882 with realtime DTS encoder, MSI 945 Platinum mb)
    as I'll use only digital SPDIF out to denon3805
    I've had Maya MK2, but my old pc's integrated sound didn't had optical spdif out, so i couldn't compare, but the difference using analogs was HUGE (as it supposed to :)
    Current plans were to go for esi juli@, but i'm not sure, since all procesing will be done in denon..
    PS
    don't those integrated soundcard do FORCED conversion to 48KHz?
  2. DaveP
    DaveP
    There seems to be conflicting opinions on this subject!
    I suggest you try the on-board sound first and see if you are happy with the quality.
    My view is that if you are just using passthrough there is little point in spending a lot of money on a card that specialises in decoding the digital stream to 7.1 channels of analogue that you don't need. I'm sure the 3805 does a better job!
    Stand well back and wait for arguments from the other camp!
    Dave
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    My experience is that on-baord SPDI/F is fine, either optical or coax, but on-board D/A often leaves a lot to be desired.
    I use ASUS boards, my HTPC uses a P4C800E (PCI/AGP) while my games PC uses an Audigy 1 . Listening to my 3803 I can't tell the difference, although some 'audiophiles' allegedly can tell that the mobo probably ha worse jutter .. at my age clearly I cant' discern this difference. :)
  4. TheCrow
    TheCrow
    Jul 16, 2004
    659
    2
    28
    London
    +76
    I am just getting to grips with this myself, but I beleive all but a few expensive pro soundcards force conversion to 48kHz.
    It is related to Microsofts Kmixer software/driver so the only way round it is to use an alternative like ASIO or Kernal Mixing but you also need a frontend software package that supports these.
    Sound cards from RME seem to be popular for this application.
    P.S this is not an issue for DVD Dolby Digital or DTS but mainly for music playback as all CDs, MP3 etc are 44.1kHz
  5. rmask
    rmask
    Mar 25, 2005
    115
    +4
    most esi soundcards (including audiotrak brand)
    dont
    i can confirm that for audiotrack maya mk2
    porbably the same for other brands based on envy chip?
  6. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    I prefer my M-Audio card to my Nvidia Soundstorm
  7. TheCrow
    TheCrow
    Jul 16, 2004
    659
    2
    28
    London
    +76
    I wasn't aware of the ESI Juli@ card before.
    I've just been finding info about it and reading the PDF manual and it looks very interesting.
    Could anyone confirm that you can use this card with its EWDM drivers in Win MCE to enable play back of music from the MCE frontend at 44.1kHz via the SPDIF output?
  8. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    Not 100% sure what you want but from what i understand you want to output sound to a denon amp?
    If so then look for the HDA X-Mystique. It's one of the only cards with an onboard 5.1 ENcoder meaning it can encode it to 5.1 and send to your amp over optical. Then your amp decodes it and plays in 5.1 godness
  9. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    What differences do you see .. er, hear ? .. enquiring minds want to know. :D
    I'm referring to SPDI/F here as that seems to be what the OP is interested in.
  10. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Also there is a Turtle Beach one with a dolby digital encoder...
  11. rmask
    rmask
    Mar 25, 2005
    115
    +4
    after some google research seems that integrated chips FORCE upconverting to 48KHz (could be misstype or missunderstanding) and only passes through digitaly encoded content (dolby, dts, etc) untouched..
  12. rmask
    rmask
    Mar 25, 2005
    115
    +4
    I've purchased juli@
    and can confirm TRUE 44.1KHz 1:1 digital signal passthrough
    btw
    the quality using analogs is amazing (although i use digital passthrough directly to the amp :p and analogs only for recording)
    quite comparable to those of denon's 3910 player
  13. TheCrow
    TheCrow
    Jul 16, 2004
    659
    2
    28
    London
    +76
    Hi rmask,
    I too purchased a Juli@ for my MCE machine but I am having some issues with it.
    My main problem is with DVD and TV playback, I am getting jumps in audio and picture. Where as if I use my onboard SPDIF everything is fine.
    Can I ask what software you are using in your setup for 44.1kHz 1:1 playback? I can only acheive this with Foobar Kernal Streaming and not MCE (Tested with a 44.1kHz DTS CD).
    Do you use your system for video playback?
    If so what software are you using and have you noticed any problems with the timeline?
    I have been speaking to ESI support and must say they are very helpful so hopefully we can figureout what's going wrong.
  14. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Not all . Some do some don't and some can bypass the kmixer stuff and some upsample regardless. its not all down to money either. The more expensice cards tend to their own clocks. Some say this makes a difference .
    None of this is an issue for dvd/video playback as its 48kHz anyway. This resample business only applies only applies to CD type audio.
  15. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,153
    +1,177
    I've not tried SPDIF, but for analogue out, the £50 M-Audio Audiophile, happily bypasses microsoft's software, with ASIO and Foobar (so not converted to 48kHz)
  16. nwgarratt
    nwgarratt
    May 5, 2002
    27,189
    +3,038
    I have been using onboard sound since 1999. I find it perfectly acceptable and currently use onboard SP/DIF to a AV amp.
  17. rmask
    rmask
    Mar 25, 2005
    115
    +4
    no special software, auto in sample rate controls, using optical out directly to denon
    make sure you select ch34 for spdif i/o
    and that its selected in your dvd software
  18. rmask
    rmask
    Mar 25, 2005
    115
    +4
    which is (44.1kHz) the majority of audio most of us listens to (including compressed formats) :)
