Are there any cd players with voltage selection.
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Jimmysil, Nov 26, 2004.
  1. Jimmysil
    Jimmysil
    Hello Peeps
    As some of you may remember, I recently moved from Essex to Canada.
    The problem was I had to sell my beloved system, which included a Rega Planet CD :( .
    I brought a setup in Canada which I am happy with, but I am using a Nad T533 DVD as cd player. So I would like a good cd player.
    The problem is that Canada, cheap 2nd cd players don't seem that easy to come buy.
    As I am back in the UK for Xmas, I was wondering if there are any good cd players that have a voltage switch on the back. Most I have looked at on ebay, don't appear to have a switch.
    Any ideas ?
    James
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Arcam CD players (CD73 et al, but not the earlier ones) and all DVD players have a voltage selector switch.
    HTH.
    John Dawson (Arcam)
  3. Jimmysil
    Jimmysil
    Thanks for the info John.
