Question Are The Kef Q8s Satalite Speakers Good Enough For Surround Rears? Which Brackets For Tilting Them?
Discussion in 'What Speakers Should I Buy?' started by mr gothic, Jun 9, 2018.
  1. mr gothic
    mr gothic
    Aug 25, 2002
    1,594
    leigh
    +51
    kef q8.JPG hi
    are the kef q8s good enough for surround duties for the marantz sr6012 av amp which i will be buying soon to replace a pioneer lx87 to get the newer surround formats?
    my couch is close to the rear wall and have 2 pairs of the q8s boxed up i had years ago and was wondering if they are good enough for todays soundtracks at the moment i have 2 pairs of mission 77ds as surround duties?
    i have kef 103 reference floorstanders from the 80s which i love for fronts and a kef q95 centre which i need to replace as its quite small and need something a better[any ideas welcome which would match the floorstanders?]
    also looking for suitable brackets which are tiltable?
    all input welcome for my centre and rears.
  2. gibbsy
    gibbsy
    May 17, 2007
    11,998
    3
    Cwm Cynon, De Cymru
    +6,373
    I think the Q8s would be perfect for the job. They have UniQ drivers which will give a good dispersion and should fairly well match the timbre of the 103s. As for a centre you would have to search the classifieds for an older version but probably the R200C would be a good shoe in.
  3. mr gothic
    mr gothic
    Aug 25, 2002
    1,594
    leigh
    +51
    thank you for your reply and advice will keep an eyeout for a used centre you mentioned.
  4. mr gothic
    mr gothic
    Aug 25, 2002
    1,594
    leigh
    +51
    any ideas for brackets which will tilt and fit the kefs
  5. gibbsy
    gibbsy
    May 17, 2007
    11,998
    3
    Cwm Cynon, De Cymru
    +6,373
  6. mr gothic
    mr gothic
    Aug 25, 2002
    1,594
    leigh
    +51
