I have used every combo of search terms I can think of to get an idea and no luck. Here is my situation using a Yamaha RX-A3080 in 7.2.4. I recently added rear heights and had to use an old ancient 100W amp I had laying around to assign to the rear heights. On a couple Blu Rays with heavy action and LFE (the end of Top Gun was one) the receiver shuts down. I do have an Infinity fan atop it and the temp stays pretty stable.
My question is during scenes like this which channel is taxing the amp the most and would be best all around powering separately? My guess would be the fronts and if so would getting them on the seperate amp eliminate that rare shutdown, again only happening on a couple scenes in a couple films. I'll list what I am using to help with any suggestions. All SVS. Fronts are Ultra bookshelves and Ultra center, 4 heights and 2 rear surrounds are Prime elevations, side surrounds are 2 Prime sattelites, subs are two SB3000.
I see posts about amping fronts and center by themselves but I'm not sure I saw a way to do that and assign it that way. Also out of curiosity, what is activating the shut down? My guess is it's not heat or you could not restart and just roll along just by hitting the power button. Something would have to actually cool down. Seems more like whatever it is is acting more like a circuit breaker. It used to happen on my old Yamaha 5.1 as well under the same type of taxing condition.
