Are tehse 2 lenses on with the D50?
shaolin101
Hi, As above really - Saw them cheap but wasn't sure if they were for digital or not - owner didn't know.
Nikkor 70-210mm AF Lens 1:4-5.6 Auto Focus GC
and
Nikkor AF 50mm Lens 1:1.8
Many thanks
Benrudd1
Both of those should work fine on the D50.
I have the 70-210 which I use on my D70 and it gives good results.
You just have to set the aperture ring on the lense to the largest number where it should lock so that the camera can control the aperture.
You should find that all AF lense's will work fine on the D50, you just have to avoid the manual focus one's as they won't meter at all.
Hope this helps :)
