Are Sanyo any good
Discussion in 'General TV Discussions Forum' started by DPS, Jun 17, 2001.
  1. DPS
    DPS
    My budget is around £700 but is deminishing every day due to the fact i can not decide on a decent widescreen set and am spending it on other things.Are Sanyo tvs any good its not my prefered choice of manufacturer but i came across a Sanyo 32wn4 for around £610.Any one own a Sanyo as i would be interested in your opinions do they support ntsc and are there any known rgb problems.
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    They are ok. Reliability is as good as any other.
    However, the user controls for things like brightness, contrast, colour etc can be a bit wanting. The pic is ok but not the best.
    Only real probs I remember seeing on them are, dry joints on the pcb, the odd tube flashing over, the remote can lose its rubber buttons easily if picked at, ie, kids.
    Otherwise it's down to taste. At £610 it's a fairly good set. I have some old tech stuff on Sanyo stuff if you want it. A CD ROM on the W3/4 range with vcr's.
