Are QED micro good for fronts?
Discussion in 'Home Cinema Speakers' started by Wilt, Feb 8, 2009.
  1. Wilt
    Wilt
    May 13, 2004
    1,032
    48
    Mitcham, Surrey
    +30
    They suggest that these are good for mini sysytems are rear speakers, but i need cables to go under carpet for my fronts which are M&K M7s.
    Are these fine?
  2. MI55ION
    MI55ION
    Nov 8, 2005
    5,851
    +690
    A bit thin for the fronts I should think, wouldn't take the chance without comparing them against the thicker alternative.
  3. paulr2006
    paulr2006
    Jun 30, 2007
    9,528
    Nottinghamshire
    +2,506
    Buy this you will not regret it. It's actually quite a thick cable (2 x 1.25mm) despite being called micro but it is so much better than the standard micro IMO :)
