Are Pico Projectors an option for (very) low budget bedroom cinema?
Discussion in 'Projectors, Screens & Video Processors' started by NatDaGamer, Jan 5, 2012.
  1. NatDaGamer
    NatDaGamer
    Nov 22, 2011
    37
    I would like input as to whether a pico projector is a good idea as a movie watching (and maybe gaming) solution. It'd ONLY be connected to my pc (running a 22" 1080p monitor) and would probably only really be used at night, although if I wanted to at daytime, I have blackout curtains which block 80-90% of light in my room. Ideally, my budget is under £90, but I may be willing to save up a little more...
    I can get a manufacturer refurbished Aiptek V20 for about £75 inc p&p or the Aiptek T15 for around £55 inc p&p (same place). I wouldn't mind buying second hand, and would maybe use 2-3 hours every few days (partly why I don't want to invest too much). The projection distance would be just under 2.5m if thats any help.
    If you want any more info, or if this isn't clear, please say :)
  2. toddy28
    toddy28
    Aug 20, 2007
    3,634
    +685
    Only VGA res 640x480 I wouldent bother your better of saving up around 200 and getting a good second hand 720p projector like a hd65
  3. NatDaGamer
    NatDaGamer
    Nov 22, 2011
    37
    thanks, guess i've got a few months of saving then xD
  4. NatDaGamer
    NatDaGamer
    Nov 22, 2011
    37
    I can get a Sony VPL-EX3 for £85 or so, I think i'm gonna go for that
  5. stevelup
    stevelup
    Aug 13, 2002
    6,608
    Swindon
    +1,144
    That's a data projector - far from ideal as a cinema unit.
    Just save up a little bit extra and you'll be able to do this right. You really want something that's natively 16:9 and 720p. Have a look on the classified forums here. You should definitely be able to pick something up for £200 ish.
  6. NatDaGamer
    NatDaGamer
    Nov 22, 2011
    37
    What about the Acer X110?
  7. True Romance
    True Romance
    Feb 7, 2005
    6,863
    Wolverhampton
    +2,940
    Thats a 4:3 panel, try looking for a 16:9 unit.
  8. NatDaGamer
    NatDaGamer
    Nov 22, 2011
    37
    I'm having trouble finding a reasonably priced one. if I won't be using the projector more than one movie every couple of days, is it worth getting a 16:9? I probably wouldn't mind a letterbox effect. Also, due to age, I'm not allowed to post in the classifieds section of the forums :(
  9. ShanePJ
    ShanePJ
    Well-known Member AVForums Sponsor
    Jun 20, 2006
    2,251
    116
    Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
    +566
    Not many people use there projectors on a daily basis. S/H projectors to search for.
    Hitachi PJ-TX200,
    Hitachi PJ-TX300,
    Panasonic PT-AX100,
    Panasonic PT-AT200,
    Optoma - Themescene HD65,
    Sony VPL-HS50,
    Sonly VPL-HS60
    These are the some of the better 720p projectors out there. There are many others, but this will give you a good starting point and a firm footing onto the home cinema projector experience. Good look searching.
    Also remember that many projectors only output an image and no audio unlike your iPad.
    Regards, Shane.
  10. NatDaGamer
    NatDaGamer
    Nov 22, 2011
    37
    thanks for the list, having a look now to see what i can find :)
  11. stevelup
    stevelup
    Aug 13, 2002
    6,608
    Swindon
    +1,144
    Sanyo Z3, Z4 and Z5 all worth consideration too.
  12. nwgarratt
    nwgarratt
    May 5, 2002
    27,375
    +3,096
    Optoma HD700 too (black version of an Optoma HD65)
    You will still get a letterbox effect with different aspect ratios anyway but with native 4:3, they will be even bigger.
  13. NatDaGamer
    NatDaGamer
    Nov 22, 2011
    37
    anyone know a website (other than the 'bay) where i can find these projectors?
