Are my rears to "small"
Discussion in 'Home Cinema Speakers' started by Kobus, Mar 30, 2005.
  1. Kobus
    Kobus
    I am busy setting up a new system. I have BW803's for the front and will be getting a Pioneer AX5Ai receiver. I know the receiver is underpowered for the fronts, but that is all I can spend now. BUT, I am planning on using my old B&W DM110,s for the rear (for now). They have a power rating of up to 75W and the Pioneer has a max output of up to 120W (I think). Am I at risk of damaging my rears, or is it not such a problem as they are rears and will not be working so hard.
    Thank you
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Since you'll be very careful ( ;) ) not to try to over-drive the large fronts with a (slightly) underpowered amp, you're smaller rears will be fine. :)
  3. Kobus
    Kobus
    Thanks, I'm glad you think that the amp will only be slightly underpowered.
    And, I had to ask this some time - what's with the springbok. Any connection to us down here.
  4. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I used an old pair of DM110 to temporarely replace my burned surrounds, and they play more than loud enough for that part, now they might not match the 803´s timbre that well... :rolleyes:
    It is also good they they are closed boxes as they will probably be used close to the wall... :smashin:
  5. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    I'm South African. Grew up in Cape Town. Now I'm wasting my life in the UK. :(
