Are "Magic Codes" possible on Sky+ remote?
Discussion in 'Sky Digital TV Forum' started by Jon Weaver, Feb 9, 2002.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,016
    Born in Bristol but now in Newport, (for my sins)
    +648
    I always wanted to map the cursor keys on my 'Sky Digital' remote to operate the TV.
    I never though that it was possible, but a few months ago, I stumbled upon some info.
    If you do the following, you can map a function to a button:
    TV
    Hold Select+Yellow until LED Blinks twice
    994 (LED Blinks Twice)
    Select
    ALL-4-ONE MAGIC CODE
    Button to be programmed.
    After a lot of searching, I found the following codes for a Sony TV:
    Up=323
    Down=575
    Left=563
    Right=300
    Split Screen=732 (Map to 'i' button)
    Swap Split=477 (Map to 'help' button)
    My Sky remote now did all the controls that I needed on my TV.
    However, the Sky+ remote doesn't seem to do this!
    You get the blinking LED when you press Select+Yellow, but 994 doesn't do anything.
    Are 'Magic Codes' possible on the Sky+ remote?
    Jon
