Are MA Bronze B2s overkill for centre rear channel?
Discussion in 'Home Cinema Speakers' started by steve 111, Dec 7, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Want to upgrade to 7.1 from 5.1 and keep the tonal quality of my existing set up which is all from the MA Bronze series. As i want to wall mount my speakers i can't use the B1s as they are rear ported so would have to go to B2s.
    At £180 a pair are these overkill for the centre rear channel?
    If so anyone any recommendations on front ported bookshelf speakers up to £120 that would do the job?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Why not try the Bronze BFX which are designed to go on the wall.
  3. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    BFXs are the same price as B2s plus bi/di-pole are not advised for centre rears.
