Are external DVD writer / players multi region?
Discussion in 'Desktop & Laptop Computers Forum' started by IanB, Dec 2, 2004.
  1. IanB
    IanB
    Nov 1, 2001
    101
    16
    Shropshire UK
    I've gone and used up all my lives on my internal superdrive in my G5 mac. I'm now stuck on region 2. That's not so bad, but I have quite a few R1 and R3 disks that I like to have playing on my second monitor while I'm working.
    I as thinking of ripping out the superdrive and replacing it with another, there isn't any firmware flashing software for this superdrive (SONY DVD RW DW-U10A) by the way. But there is nothing wrong with it, so why waste it?
    If I bought an external, at least I would have some back up if it did ever pack up.
    What I don't want is to buy an external and find it's stuck in a particular region as well. I've looked and looked and I can't find out any details. Does anybody know if they are region free?
    If so does anybody have any recommendations for an external with firewire?
    I'm just looking for a player really, but these days, it just as cheap to buy a writer.
    All help appreciated.
  2. broona
    broona
    Aug 26, 2004
    5,382
    Hexham
    +547
    All drives come region locked, but most can be unlocked by flashing with new firmware, this can be found here. Hope this helps. :)
  3. IanB
    IanB
    Nov 1, 2001
    101
    16
    Shropshire UK
    OK. :cool:
    Thanks for that. It looks like the firmware flashing progs are PC. Do you know of any Mac versions?
    I don't have a firewire port on my PC so that will mean I have to buy a USB external and I'm not too keen, I'd rather have firewire.
  4. DaveP
    DaveP
    I just had a look for my drive and there is a Region code resetter for Mac for that drive. If you try a search for macintosh you may end up with a shopping list of suitable drives.
    Dave
