Are DVD +Rs region concious?
Discussion in 'Blu-ray & DVD Players & Recorders' started by the_sanguine, Jan 3, 2007.
  1. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    Is all the R1,R2 crap only on pre-recorded discs?
    I'm looking at an in-car DVD player that will play DVD +Rs. Am I right that it makes no difference that it't R2 only? Therefore the only constraint is that it will only plat R2 pre-recorded material?
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,854
    103
    +460
    Yes, your own DVD's are region neutral.
    Regards
    Phil
  3. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    Thanks. I did suspect that. Looks like I'm in the clear then....
    Out of interest, can you copy a DVD that's Region 1 and make it region nuetral?
