Are DVD -R discs not compatible with all players
Discussion in 'Blu-ray & DVD Players & Recorders' started by DonMaico, Jan 1, 2005.
  1. DonMaico
    DonMaico
    It would seem not as I tried to play one ( on which I had recorded some material using a Panny E55) on my Toshiba SD520E and all | got was a peculiar noise coming from the player itself plus the message " loading" constantly repeated. Are there other record once types of software out there? :confused:
  2. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    No DVDR media is compatible with every single DVD player. DVD-R, with between 93 and 97% compatibility with existing machines, has the best chance of working though.
    If you consult the DVDR Help database reference for your player:
    http://www.videohelp.com/dvdplayers.php?DVDnameid=1762&Search=Search&#comments
    You'll see that several people have got DVD-Rs to work. Your best bet might be to try a different brand of media and see if you have more luck.
  3. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Had you finalised it?
    Unfinalised DVD-Rs will usually only play on the originating machine (or one of the the same make) so that you can add recordings until it is full, if you wish. Then you finalise it and it's portable, but you may get the odd player which is unhappy. Changing disc brand might help.
  4. DonMaico
    DonMaico
    That might explain it if by finalising you mean did I fill the dvd completely which I havent as I only wanted about 2 and half hrs of recorded material .How do you tell how much space there is left? And does it mean I have to fill the dvd completely ?
  5. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    No - you finalise when your finished with disc regardless of how much space is left on it. You do this by going to Functions/Disc Information and select 'Finalise'. Just like a CD-RW/-R...
  6. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    ... and when it is finalised you cannot add more recording to it.
  7. DonMaico
    DonMaico
    Oh ok . What I did was copy recordings made from a hard disk ( sky plus ) recorder. Didnt realise you had to finalise things :blush: :thumbsup:
