Are copied CDs lower quality?
Discussion in 'Music & Music Streaming Services' started by Pezerinno, Jun 30, 2005.
  1. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
    Hi, I was just wondering if a copied CD sounds worse than a original CD? I tend to backup all my cd's by coping them however if they loose quality perhaps there is a better way for me to do this?
    Thanks.
  2. FeisalK
    FeisalK
    Jun 9, 2005
    375
    KL
    +21
  3. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Nick interesting reading for you to peruse, I notice no difference with CDR to originals, and that is not just normal redbook 16/44.1 but also 20/44.1 copied WAVs burned onto CDR. The thread belows get quite interesting at about pages 7-9, I even posted off a CDR for someone to blind test and its worth reading those posts.
    http://www.avforums.com/forums/showthread.php?t=140722
    I have though noticed on some fast speed burns, ie 4X+ that I create quite a few coasters, that is CDRs that jump etc etc, I would say then that slower burn speeds create less problems ie error correction detection on some optical laser assemblies. I always burn at 1X or 2X, at these speeds its impossible to tell the difference to the original. Above that and I have some older CDPs that struggle with the “quality” of the CD. Ie skipping etc, when the error correction is too much for the CDP to handle.
    Anyone (IMHO) saying different should try some blind a/b tests with the original CD (superior) and copy (inferior) and be able to identify each, I could not at all when I tried. And I don’t know of any properly conducted tests in the blind domain that have tried it TBH.
  4. mjn
    mjn
    May 24, 2001
    22,091
    Herts, England
    +9,838
    As soon as he says this......."we can now consistently make a copied CD sound spectacularly better than the original." You know he's talking out of his arse!!
  5. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    :rotfl: :rotfl: :rotfl: :smashin:
    Could not have put that better myself mjn.
  6. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
    Thanks for the replies - will get reading! I tend to burn at 2x when copying my cd's and 40x for anything else (data etc).
    By the way CJ my Dad is using the Tag dac at the moment while I sort out my system - he loves it so might have some trouble getting it back! He isn't an audiophile by any means either.
  7. mjn
    mjn
    May 24, 2001
    22,091
    Herts, England
    +9,838
    Using an external DAC will give better improvements compared to using different blank CD's IMHO.
  8. sandstheman
    sandstheman
    Jan 6, 2005
    545
    28
    +49
    There will always be a small amount of difference between an original and a copy, but it's never enough to be noticeable on any scale, with the exception of burning coasters of course - but generally speaking a copied cd should be just as good as the original, it's only when you start making copies of copies that at some point down the line the degradation becomes noticeable
  9. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    Exact Audio Copy
  10. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Why ? Please explain why this software makes better copies than others ?
    An un-compressed WAV file burnt to CDR and thus is an Exact Copy of the original. Or am I missing something here.
    Nick tell your dad he has fine taste, whats the rest of the system he is using it in, please say a nice stereo amplifier with decent speakers. :D
  11. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Aye that 'twer I and the results were as conclusive as possible using a high quality HiFi system with very revealing speakers. Could'nt tell the difference and ended up buying two Cds :rolleyes: by one of the artists on the compilation.
  12. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
    Couldn't tell you exactly but I know he has a yamaha tape deck, arcam amp/cd player/DAB and rega lp player/speakers. Not sure on the model numbers though. Not a comet own or anything :D
  13. FeisalK
    FeisalK
    Jun 9, 2005
    375
    KL
    +21
    ok he went overboard there :p
    doesn't mean you can't try it out yourself, and possibly benefit from the article i.e make at least a few back-up copies which are as good as the original :)
  14. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    I read the article, downloaded EAC and tried it and yes the copies I've made are better than what I was getting, but for playing in the car etc I'm not that bothered as they get slung around.
    And although I too think his talking crap about the copy being better than the original. I think what his trying to say is that in theory if EAC copied a disc and made a better job of it with multiple reads correcting the errors that a CD player could never do while playng a disc, then that image burnt to a CD could be read by a CD player with less errors than the original, so in theory because the CD player has to work less hard it should sound better. But can any copy ever be better than what it was copied from. I think it's all speculation.
  15. HD3
    HD3
    The short answer is NO quality loss at all as long as you do a DIRECT copy from one CD to A CD-R you will not be able to notice any difference.
  16. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Hang on you are using a laser here which is dependant on the reflectivity of the disc, marks, scratches. You are going to always get some loss just reading the disc, and the units error correction will have an effect on that.
    If you have ever tried to copy a disc multiple times one after other you can hear a difference between the copies and thats using the same make of disc and burning at a low speed.
  17. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    Livingston, Scotland
    +227
    Providing you are using decent blanks (ie = 99% of what is generally available) any differencies will be negligible if copied bit for bit.
    In fact I doubt wether most people would hear the difference if the bit rate was lower :eek:
    There is an argument from some quarters that recording at a higher rate or upsampling can be beneficial.
  18. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    And what about the quality of the clocks in the CD recorder? I doubt very, very much that a £300 CDR would incorporate a high-quality jitter-reducing oscillators of the type found in £1000+ CDP's.
    I'm guessing budget CDR's probably use mulitple feeds from the same (cheap) master clock. If a CDR has average read error of, say, 800 picoseconds, and av. write error of 800 picosends, the compound effect would probably become quite noticeable. And we haven't even taken into account the quality/consitency of the laser and media yet!
    I doubt there is "no degridation" in quality when burning a CD using budget recorders.
    DT
  19. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    +227
    Turtle
    I still honestly doubt if you will notice unless things are really bad. Over the years I have only been "let down" by a copy once. Saying that I don't copy from the net or buy pirates, I only make my own.
    I use a Traxdata CD-Recorder I got a long time ago from Richer once in a while but mostly use my Dell PC or Toshiba laptop at 54x dub. Blanks range from Maxell, TDK, Memorex but mostly Datasafe at 5p a go from blankdiscshop.co.uk.
    I'm not saying that there will be no degradation just that most people wouldn't notice.
    Replay is on my full TAG McLaren system
  20. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    True i admit unless you then go and compare your orginal and copy most may not notice or just not care.
    I personally could hear a difference between master and copy and between copies on a car stereo (usually in the symbols).
    Another thing you can question are players that offer bit extension to 24bit or upsampling to 192Khz. You are only "inventing" information form the original. How do you know what it has done is correct?
