raven219
- Joined
- Mar 5, 2001
- Messages
- 583
- Reaction score
- 23
- Points
- 281
..... If all I want to do is stream files from my NAS (various codecs). And by cheap I mean in the £30 to £50 region.
Thanks.
Thanks.
If you want 4K HEVC and HD Audio go for WETEK Hub. AFAIK, RP3 doesn't support 4k HEVC and no cheap android device supports HD Audio.I was hoping to get something that supported 4K/HEVC and I don't think the Raspberry Pi can do that.
Thanks bubblegum57. Great link.
Going to get one of these and try it out for live tv, every other aml box i have had has been excellent for deinterlacing.I bought a Beelink Mini III from gearbest, Beelink MiniMXIII TV Box 1000M LAN & have used the LibreELEC s905. It works well. The good thing is, that you don't touch the Android part, LibreELEC is on a sd card.
Amlogic | LibreELEC
I had no problems installing this image. POP
Its the amlogic s905. I used rufus to create the image on the micosd cardGoing to get one of these and try it out for live tv, every other aml box i have had has been excellent for deinterlacing.
Which exact LE image do you use? Is it Kczak's 7.002? The thread on the LE forums is massive and a bit confusing...
Do let us know how you get onThanks for that. Have ordered a Sunvell T95M for £30. Will give that a try.
