Are bulbs covered under warrenty?
Discussion in 'Projectors, Screens & Video Processors' started by Mr. Flibble, May 16, 2004.
  1. Mr. Flibble
    Mr. Flibble
    I bought a projector just under a year ago(NEC LT240) and the bulb has blown after about 500hrs use. Shoud this be covered under warrenty? Should it last about 2000 hours before needing replacement?
    Also, is it possible to check the usage time when the bulb is blown?
  2. nero0410
    nero0410
    Jan 5, 2004
    11,943
    southwest
    +4,560
    I think you may find that it is only covered for the first month, as it is with panasonic. I would still get in touch with the nec though just to double check.
  3. inzaman
    inzaman
    Dec 16, 2002
    7,955
    Derby
    +1,021
    Has nero has said i think that most are covered for one month only and thats it, unfortunately
