Are brackets for Owl motorised screens universal for each size?
Discussion in 'Projectors, Screens & Video Processors' started by zamwessell, Jul 12, 2004.
  1. zamwessell
    zamwessell
    Jan 2, 2003
    1,196
    +120
    I just bought an Owl Othello 5' wide motorised screen.
    As the wall/celing mounting brackets allow for the screen unit casing to be 'hooked' on easily, i was wondering if i could hang on a 6' or 7' version on the same brackets.
    I would like to dem a 6' or 7' screen just to see if i could prectically upgrade to a bigger size within the limits of my room.
    Thanks in advance.
  2. Kramer
    Kramer
    I'm not 100% certain but I would imagine the brackets are good for bigger screens from the range.
    A quick call/e-mail to Owl should clarify.
    :smoke:
  3. stevelup
    stevelup
    Aug 13, 2002
    6,511
    Swindon
    +1,088
    I'm 99.9% sure that all the Othello screens use the same extrusion - therefore the same brackets will fit any screen.
    Steve
