MAW
How do shop@panasonic connect? In Guildford it's all composite video, or was when I was last there. They are franchises, so no standards, entirely down to ownership.
Originally posted by loonatic
It's defo not your Sky box as it also happens on DVD via either component or HDMI and PC input.
Cheers, Lee
MAW said:It might be a processing problem, ditch the tuner models, try some panel only types. At least you get control of the processing. There's absolutely no need for an integrated analogue tuner, most people never watch them anyway.
I've just tried this and I can just about see the effect you're talking about.loonatic said:Okay then..try this...
Bring up the Sky+ TV guide and move the highlight bar up and down.
While doing this look to the left and right of the highlight bar and you should see a change in brightness corresponding to the moving bar.
Cheers, Lee
loonatic said:You can clearly see the problem if you bring up the Sky navigation menu at the bottom of the screen and look either side of the blue on-screen channel selector you can see that it has changed the brightness/contrast of the underlying image. This I guess on its own could be lived with.
loonatic said:LCDs do not seem to suffer from this problem.
They produce a much cleaner image...until something moves..allthough this is improving all the time.
Cheers, Lee
