Are all plasma's 2 frames late???
Discussion in 'Plasma TVs Forum' started by Weird Wolf, Mar 1, 2002.
  1. Weird Wolf
    Weird Wolf
    I'm new to home cinema and i was chatting to someone last night who works in TV industry (as do I) and they found that plasma screens are all 2 frames late with respect to the audio. Apparently they called Panasonic and after initially denying it they confirmed that yes, they are late. Obviously if this is true, then the audio will need a delay box in order to rectify this.
    This has shocked me a bit especially as i've looked at various forums and none of them have mentioned this....is it true or am I missing something previously discussed?
  2. Ludae
    Ludae
    Usually 1 to 3 video fields delay (0.5 to 1.5 frames), due to the de-interlacing required. Most people don't notice or have a problem with the delay, but if there are sync errors elsewhere, such as from the DVD player and/or movie mastering then the problem becomes much worse.
    There are some audio amps/surround sound processors that allow the audio to be delayed.
  3. Weird Wolf
    Weird Wolf
    Generally speaking a 1 frame delay is kind of passable but 1.5 frames is definitely noticeable. I'm getting the Denon 3802 amp/receiver so i'll look to see if this delays or not.
    Thanks.
  4. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    The 3802 doesn't have lip-sync delay
    Regards
  5. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    The case is the same with 100Hz sets, they have a delay of at least 1 field.
  6. Ludae
    Ludae
    I think it is half a field plus half a scan line IIRC for the simple repeat field 100Hz mode.
  7. philipb
    philipb
    Mar 6, 2002
    2,085
    63
    Swindon
    +172
    Well thanks guys. Have been happily watching my plasma for nearly a year, now I'm looking for lip synch delay. Some things you're better off not knowing.
    In fact I can't see it most of the time on my Daewoo, although there was some slight lag on last night's screening of Star wars 1 on Sky.
    BTW, just adjusted my screen using the Avia test DVD - wow what a difference. I have access to the factory settings of the Daewoo via a hack on the remote and by tweaking these the picture is much improved. The component input shows the greatest improvement (hooked up to a Sony 9000ES), but the S-Video feed is also a lot better.
