tonytaylor1967
- Joined
- Mar 24, 2010
- Messages
- 37
- Reaction score
- 2
- Points
- 33
Hi all, I don't know if there is already a post on this, but I can't find one.
A couple of questions - Are all HDMI leads fully wired and if not how do you know when you buy one, that it is fully wired?
There are cheap ones from the likes of asda and the very expensive ones. I can't recall any of them saying that they are fully wired..
Also do the more expensive one give you better picture and sound quality, when as far as I understand, it is just 1's and 0's. Not like scart leads or audio leads where the signal is an analogue one and the quality of the cable does make a difference.
Hope some one can answer to the above.
Tony
Tony
