Answered Are 4k Discs worth it?
Discussion in '4K Ultra HD Blu-rays' started by johnr2110, Dec 12, 2018.
    1. johnr2110
      johnr2110
      Aug 26, 2006
      2,751
      2
      2
      68
      Eastbourne
      +94
      Got the TV got the Player just need to buy discs to get the full benefit. Being a synic I’m wondering if there a really any benefits over standard Blu-ray.
      My TV is a 55 inch Panasonic and viewing distance is around eight foot.
    2. Best Answer:
      Post #14 by StefanBFC, Dec 13, 2018 (2 points)
      See Also:
    3. andym81
      andym81
      Nov 13, 2016
      442
      28
      GB
      +81
      Really depends on the films. I own around 8 4k uhd some don't look much better than the blu rays. You need to check whether the disc is native 4k or 2k upscale.
      Then there's HDR to take in to account
    4. StefanBFC
      StefanBFC
      Jul 17, 2006
      967
      3
      46
      Bury, Greater Manchester
      +225
      Like above, just a select few. Probably your most preferred films.
      In a few years I'm guessing the price of what you own will decline massively.
      I almost sold my player until I watched Darkest Hour, the picture quality was unbeatable on anything streamed.
      • Like Like x 1
      • Agree Agree x 1
      • List
    5. johnr2110
      johnr2110
      Aug 26, 2006
      2,751
      2
      2
      68
      Eastbourne
      +94
      Thanks for the input,how to you tell whether they’re native or upscale?
    6. Cord Cutter
      Cord Cutter
      Oct 20, 2005
      21,470
      Ashford, Kent
      +2,555
      Simple answer...no
      • Agree Agree x 1
      • Wow Wow x 1
      • List
    7. furryhobnob
      furryhobnob
      Jan 15, 2010
      14,473
      Hugglescote
      +7,202
      Depends on your tv as most say they can do hdr but not within the uhd alliance specifications, as hdr is a bigger improvement than the resolution, if your tv is anything but a high end one like an oled, or a fald lcd or some edge lit lcd's then the hdr will be lacking, the scientific calculator reckons on a 55 inch screen you have to be sat closer than 1.2m to see the difference between 1080p and 4k resolution, but to benefit from hdr you can be sat any distance, but like I said it depends if your tv can do hdr justice
      • Thanks Thanks x 1
      • Agree Agree x 1
      • List
    8. John7
      John7
      Aug 6, 2004
      2,740
      +922
      55 inches at 8 ft is probably on the border of visual acuity to see the diffenrence (in pixel dimensions) between hd and 4k. However, 4k has hdr and dv, not to mention the far more iimersive atmos audio.
    9. furryhobnob
      furryhobnob
      Jan 15, 2010
      14,473
      Hugglescote
      +7,202
      Y
      You can get atmos audio on 1080p blu rays, it isn't exclusive to uhd blu rays, take the new BBC Dynasties, the blu ray has atmos, the uhd doesn't
      • Like Like x 1
      • Useful Useful x 1
      • List
    10. lgans316
      lgans316
      Aug 24, 2006
      12,034
      RM16
      +2,463
      Absolutely useless. HDR is crayons. VHS the way to go...:)
      55 inch and a distance of 8ft is a bit too much to appreciate non-HDR 4K. With HDR and WCG, you should be able to notice some differences depending upon the film
      To my eyes, vast majority of the 4K discs I own look better than their Blu-ray counterpart on my LG 65C8 from a distance of 7.5ft
    11. Thug
      Thug
      Jul 17, 2003
      7,569
      3
      Middlesbrough
      +3,631
      For your use I would say 'only on select discs'.
      Most of the time when I put on a disc after 5 minutes I forget its 4k in any case as I get 'into the movie'.
      Ok, you have HDR, which is quite nice. Its better on some discs than it is others though. You also have Atmos (if you can benefit from that), but then again so do some BD versions of the film too.
      If you want to sit down and watch a film then BD is still fantastic and you may not see much of a difference between that and 4K unless you pause the film and look closely at the picture.
      I view on a 65" LG OLED and a 93" projector screen (Epson 9300).
      As for checking to see if its native or upscaled, then don't let that be a deciding factor, as some upscaled are better than native.
      As I said, if its a film you really want, then get the 4k. If you just want it for your collecting then choose the cheaper of the 2.
    12. johnny777
      johnny777
      Mar 11, 2007
      468
      46
      +195
      It’s like most things.....as you increase in price, the law of diminishing returns comes into play. I’ve bought far too many, but I really enjoy that extra bit of wow factor. In addition, there is a healthy second hand market on these very forums for 4k discs so you can get back a good chunk of the outlay in most cases.
    13. mb3195
      mb3195
      Dec 27, 2007
      1,625
      2
      116
      Peterborough
      +1,558
      #2 Best Answer
      on a 55” at 8ft I would say no, not really.
      You won’t start seeing the full benefits of UHD discs Until you start going 65”+ and then utlise a full atmos soundtrack.
    14. the thing wnn
      the thing wnn
      Sep 1, 2002
      4,087
      Brecon Beacons
      +836
      I have a 55" and sit about that far away and i DEFINITELY see a difference between BD and UHD
    15. StefanBFC
      StefanBFC
      Jul 17, 2006
      967
      3
      46
      +225
      Best Answer
      This is your answer, this is exactly my thinking. The amount of times I see films I want on 4k but its £20 quid, I stop and remind myself about the 300+ blu-rays which cost me thousands & sold for about 100 quid.
      I also own 5 4k's.
      You WILL notice a different on a 55" tv, you don't need a 65" tv to realise unless your eye sight is very bad. BUT some films you'll notice it more than others.
      • Agree Agree x 3
      • Like Like x 1
      • List
    16. mb3195
      mb3195
      Dec 27, 2007
      1,625
      2
      116
      Peterborough
      +1,558
      I suppose this depends how good your tv is at upscaling. You will see a difference, but it’s not massive. The bigger the screen, the more you notice.
    17. domtheone
      domtheone
      Nov 23, 2004
      15,535
      Nottingham
      +4,238
      9-10ft away from my new 55” Panny OLED.
      Starting to go theough my BR collection again.
      All of them look good. Some of them look amazing.
      I'll still add a 4K player but i’m not rushing out tomorrow to buy one.
      I guess i really need to see for myself what difference there is from this distance since its a personal thing, given the variety of answers on this thread (and countless others).
    18. Indiana Jones
      Indiana Jones
      Nov 4, 2003
      36,739
      Bristol
      +9,483
      Are 4K discs worth it? sure they are but that doesn’t mean every disc will be a night and day difference over a Blu-Ray.
      Personally I am only upgrading those films that are personal favourites which for the most part consist of films that had average to poor Blu-Ray releases so these UHDs with brand new transfers are a huge improvement and worth every penny, really hope Universal and Paramount pull their finger out and get the BTTF Trilogy and Star Trek 1-10 released and finally do them justice.
    19. 4K UHD Fan
      4K UHD Fan
      Sep 8, 2002
      644
      43
      London
      +216
      If you can appreciate the difference & you have the equipment then yes its definitely worth it. If you do not care for ultimate quality and cost is an issue then its pointless as you will never appreciate the vast difference between a decent 4K UHD HDR vs BD.
      Not being funny but 8FT away from a 55" screen is not really going to do much for you unless you have laser precision eyesight. Either sit way closer (3-4FT) or buy a Front Projector to throw the largest picture you can at the wall!
      Over 30 years ago I used to watch movies projected onto an 8FT diagonal screen & even back then it was never big enough ;)
    20. SpuddybabyUK
      SpuddybabyUK
      Jan 8, 2017
      219
      46
      Kent
      +101
      For me it’s worth it for the immersive soundtrack
    21. iainl7
      iainl7
      Aug 8, 2006
      1,848
      +250
      I'm mainly here for others' opinions as my OLED doesn't even arrive until next week. But my current plan is that Blu-rays don't need replacing unless it's something I really, really care about (so my HD-DVD set of Blade Runner is going to get replaced, for example) but the remaining DVDs can definitely stand a new disc.
      The other thing I'd say is that for most things, the difference in price between UHD and a 4k iTunes copy means I don't know I'm going to buy a lot of discs at all. I know the disc still has the edge, but at 3m from a 55" I won't probably see it very well.
    22. Indiana Jones
      Indiana Jones
      Nov 4, 2003
      36,739
      Bristol
      +9,483
      But what about releases where the Blu-ray also has an Atmos or DTS:X mix?
    23. Graham
      Graham
      Nov 21, 2000
      1,167
      113
      Kent
      +553
      That’s one thing that annoys me - I totally get the benefits of 4K discs for the resolution, wider colour range, HDR etc but not putting the Atmos track on a Blu-ray and restricting it to the 4K format only - when the Blu-ray Disc is perfectly capable of playing it - is I feel an unfair restriction that leaves a bad taste in the mouth. Plus making the soundtracks even more restrictive for the 3D releases is terrible! The BR2049 3D release in lossy 5.1 was just unbelievable.
    24. iainl7
      iainl7
      Aug 8, 2006
      1,848
      +250
      Graham - I strongly suspect it's a space/bandwidth issue; one extra Atmos track (because the specs require you shove on a regular audio mix for players that get confused by them as well) could well be more of an issue when you're trying to get stereoscopic video onto a Blu. Particularly when they want half a dozen languages on there for the European release (sadly for fans of height channels you're a far smaller niche than German speakers, for example.)
      I remember a load of examples in the DVD days where, in order to make room for the added French track, the Canadian version of a film lost its DTS English option, or had the 5.1 DD drop to Pro Logic 2.0.
    25. Slinkywizard
      Slinkywizard
      Jul 13, 2016
      350
      UK
      +355
      They're worth it to me. Here's why, for me personally:
      • I run a 125" native 4K setup – at this scale, 4K (especially if the DI is 4K or better) is a night and day difference over the blu-ray
      • I run a 7.2.6 speaker configuration. The difference in audio between a 4K disc and a 4K stream is, again, night and day. Even people who have relatively no experience of AV have commented along the lines of 'Oh my GOD THE SOUND!!!' when moving from a streamed Atmos movie to a UHD Atmos movie
      • I like the packaging, especially when it comes to special editions like the recent Carpenter releases, 2001 and so on
      Make your own list. Only you can decide whether they're worth it for you.
      • Agree Agree x 5
      • Like Like x 1
      • List
    26. 4K UHD Fan
      4K UHD Fan
      Sep 8, 2002
      644
      43
      London
      +216
      Wherever possible support UHD discs as when they are gone you will have zero control over streaming media so the prices will increase & the quality will also drop once no disc backup is left to fall back on!
      I do not agree with everything this site says but this part is very relevant to ANY AV enthusiast!
      Hey Kids… Buying Movies? Buy Them on Disc, Not Digital. Here’s Why...
    27. Rizvan
      Rizvan
      Jan 2, 2007
      1,069
      Rotherham
      +199
      I am planning on keeping my 400-500 Blu-ray movies if they upscale good. Will buy the odd 4K UHD disc but will mostly go down the iTunes route.
      I just don't have enough space to put them all.
    28. huddy72
      huddy72
      Jun 21, 2015
      23
      Hastings
      +17
      For me, they are worth it. I've only got a 49" Samsung, so don't really notice the difference unless you get up really close, but it's the HDR that IS noticeably different. The difference in colour on Everest 4k compared to blu ray is noticeable. I've only got a 5.1 setup at the moment, but plan to get atmos in the future.
      I tend to wait a while for the price to come down or get them in a 2 for £30 type deal. £25 retail price is too much.
      My biggest gripe is why do they include the bluray disk with the 4k disk? Surely that bumps the price up.
    29. nonsoloinglese
      nonsoloinglese
      May 9, 2006
      1,917
      Kent
      +161
      I haven't read the above so not been swayed but I prefer discs as the sound is better to me than from a streaming service. Uncompressed audio is significantly better on a good system. The picture quality is not as different as the sound quality.
    30. Nobbler
      Nobbler
      Jan 23, 2012
      7,328
      5
      167
      +2,849
      The majority of Blu-ray's will look pretty much the same as the 4k disc minus the HDR and WCG. As has been said, a lot of 4k discs are upscaled and when you watch a regular Blu on your 4k player the upscaling is just taking place somewhere else.
      However is HDR and WCG is done correctly then it's worth it .
    31. MarkusThatch
      MarkusThatch
      Dec 20, 2004
      9,853
      2
      +1,832
      Same as Indiana - only really replacing absolute favourites and the odd occasional one that I then sell on if it hasn't got regular re-watch value.
      Added to your list, I'm desperate to see Raiders of the Lost Ark in 4k at some point, feels more likely than Star Wars I suppose.
