Archos to PC
Discussion in 'Video Streaming Boxes & Services' started by Andyrew, Sep 5, 2007.
  1. Andyrew
    Andyrew
    Im sure it has been asked many times however i cant find any threads on this. If i record something onto my Archos via the DVR Station, when downloaded to the PC the video will not play. How can one get around this annoying little problem?
    If i was then to transfer the file to mem stick and put in PSP would it work on that?
  2. small358786
    small358786
    Mar 17, 2007
    1,195
    48
    +83
    You dont have a MP4 codec installed to be able to play it back,it wont work on the PSP without conversion either.
    This should work
    http://www.free-codecs.com/FFDShow_download.htm
  3. Andyrew
    Andyrew
    I have downloaded but doesnt seem to do much. not sure if i actively have to do anything with it apart from uninstall?? there do not seem to be instructions. thanks for help
  4. kosovosteve
    kosovosteve
    Mar 18, 2007
    1,118
    Salisbury
    +52
    I had the same problem on my Mac.
    The reason the dvr files will not play is because they are XVID files that your PC does not support.
    Try looking for a XVID player for Windows or a plugin for WMP.
    I installed MPlayer on my Mac (not sure if there is an equivalent for windows) and I can now watch all that I have recorded.
    Hope this helps
    Steve
