Archos or Not?
Discussion in 'Video Streaming Boxes & Services' started by corseford, May 3, 2007.
  1. corseford
    corseford
    Aug 24, 2004
    25
    3
    I am currently looking to purchase a media player, primarily for viewing on the move but also for playback on TV. Recording from TV not that important. I was almost set on an Archos 404, 504 or 604 until I discovered that I would need the optional docking station to connect to TV, which makes it expensive just for playback.
    Can anyone recommend another player that can connect directly to TV via an AV cable, that has good quality picture and plays all media formats. Needs to be portable for train & plane travel.
    Thanks:lease:
  2. FrankS
    FrankS
    Dec 3, 2005
    422
    28
    +36
    The optional docking station is only needed for recording, for A/V out it's not required just the lead which goes into the headphones/video out socket. Tried my son's 404 using the cable from my 560 and it worked fine.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
  4. Eraserhead
    Eraserhead
    Zen Vision W is another option. No analog recording though, but it is therefore way cheaper. I have M version (smaller) and playback quality thru TV is great.
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    Eraserhead - Do you know what the battery life is like on the ZVW?
  6. richard plumb
    richard plumb
    Jan 27, 2002
    14,524
    Windsor
    +1,054
    I can recommend the 604. £170 from dixons tax free in Heathrow. Plays everything I've thrown at it so far. Great screen, good battery life.
    As mentioned, you can use any TV cable except the ipod one. So if you have one from your digital camera or camcorder and it has a 3.5mm jack on the end, you can use that.
    The big dock is useful to let you easily record, and it gives you better output quality - eg svideo rather than composite.
  7. Eraserhead
    Eraserhead
    According to website specs it is 13 hrs playback for Audio and 4.5 hrs for video.
    Archos has slightly higher figures, respectively "up to" 16 hours , and "up to" 5 hours. I marked this "up to" because it might in fact mean any figure lower then specified.
    OT: what about manufacturers giving us products that work for up to x hours and we pay them up to y $?
  8. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    I get peeved with the official stats too, which is why I always try to find out what the battery life is like in real world use!
