archos Gmini200
Discussion in 'Video Streaming Boxes & Services' started by kennysatman, Mar 6, 2005.
  1. kennysatman
    kennysatman
    Mar 3, 2005
    hi has anyone heard this player, what did you think of the sound? and also is the machine in general any good
  2. tcs17_tim
    tcs17_tim
    I have a Gmini 220 and I am well impressed, except for 5 hour battery life (as opposed to the claimed 10 hours)
  3. Radio_Daze
    Radio_Daze
    Jan 24, 2004
    286
    Walsall, West Mids. U.K.
    +8
    I've just bought the 220 from BT Shop online for £149.99, excellent sound with decent phones. Supplied ones not much cop.
  4. tcs17_tim
    tcs17_tim
    Hows your battery life?
    I also got mine from BTShop (I note they don't have it in stock anymore so no doubt it will be a problem!) but am now making arrangements to get it replaced after a few emails with Archos. I asked whether 4/5 hours was acceptable and the said they couldnt send me a replacement battery.
    Apparently couriers wont take batteries alone. Sounds like rubbish to me! I didnt think the battery could be replaced by the user anyway!
  5. Radio_Daze
    Radio_Daze
    Jan 24, 2004
    286
    +8
    I agree the battery life is'nt that good, but I find I get about 7 hours per charge. :thumbsdow
    It depends how you set up, I have mine to turn off the screen and backlight after 10 seconds. It also depends how you use it, if you keep searching the hard drive, this also puts a high drain on the battery.
    I think you will find your battery is OK, just try playing your Archos non stop without searching the hard drive, if you hav'nt done so already.
    I think changing the battery yourself maybe difficult, it will also void your guarantee.
    On the whole I think the Gmini is very good, but you really have to change the awful earphones that came with it. I'm using a pair of phones I had with an Aiwa mini disc recorder, and they sound great.
    If you want the FM radio tuner to go with your Gmini, you can get one from www.newmp3technology.net for £16 + about £6 postage. They are in Troy North Carolina, but their service is OK. I ordered mine on Good Friday, and it arrived the following Wednesday, just 5 days later. I also ordered the tuner for my Archos AV380 on Tuesday last, and that arrived yesterday. The price is less than half the UK price. :smashin:
    That's nonsense about carriers not carrying batteries, I had one for my AV380 (easy to change )
    from the company above when I ordered the tuner for the Gmini, so whoever told you that is talking rubbish. Apart from that I've had many NiCad NiMH batteries through the post from various companys.
