Archos AV700TV help please
Discussion in 'Video Streaming Boxes & Services' started by donnydude, Sep 16, 2007.
  1. donnydude
    donnydude
    Jul 19, 2007
    487
    +13
  2. mitchelc
    mitchelc
    Mar 20, 2006
    103
    +13
    The AV500 can record via the travel adapater but it is only composite video (yellow cable) whereas if you use the dock you can record with s-video.
    You could check the AV700 manual to see if its the same.
  3. donnydude
    donnydude
    Jul 19, 2007
    487
    +13
    thanks mate, I'm guessing taht useing s-video would give better video quality then?
  4. donnydude
    donnydude
    Jul 19, 2007
    487
    +13
    I'm also having roblems watching the digital tv on the archos. even when it is plugged into our house arial it isn't finding any channels when i scan although the arial signal on the archos can sometimes be 3/4 full on both sides!
    anybody have an idea what the problem is?
