I have an Archos AV500 and for 2 years it has worked perfectly. Now all of a sudden it hangs any time I try to delete a video file - on the screen it says "deleting file", the hard drive light comes on continuously for a few minutes then it returns to the same screen but the file has not been deleted.
I am also unable to delete any files when connecting to the PC in hard drive mode. I've tried this a few times and all that happens is the archos folder appears empty and if I right click and choose propeties it shows up as 0 bytes used and 0 bytes available.
A couple of times I've had a read drive error and it has given me the option to format the hard drive in the bottom right corner. I have tried this and it comes up saying that it's formatting the drive, but then it just comes up with the same error again and the drive has not been formatted - in fact nothing has been deleted at all. I have also tried to connect the archos to pc and format the drive that way but again this doesn't do anything.
Despite these problems, the files I do have on the machine are playing back as perfectly as ever.
If anyone has any advice please let me know. If it is a hard drive problem is there any way to fix it? Is there another way to get the drive formatted - e.g. if I put the drive into an enclosure and formatted it that way would that work??
Thanks.
Thanks.
