Archos AV420 Screen Defect
Discussion in 'Video Streaming Boxes & Services' started by CMCCMC, Sep 23, 2004.
  1. CMCCMC
    CMCCMC
    I bought an AV420 (the 20GB baby). I exchanged 3 times at the retail shop (very helpful folks)!!! After recording for around 20mins at room temp, a patch (1.5 cm in diameter!) of moisture (with oil-like rings surrounding the patch) developes as the machine get heat up. It's located in the very middle of the LCD...very very disturbing. Same problem for all 3 I had. Tal :nono: ked to the agents and they first said it's acceptable (what!!!!) but then they changed the tone and said there are actually couple complains like this and waiting for Archos to react. Pls note if you guys plan to buy one.
  2. CMCCMC
    CMCCMC
    Another photo when the patch is retreating...
