Archos AV4100
Discussion in 'Video Streaming Boxes & Services' started by davet010, Mar 16, 2005.
  1. davet010
    davet010
    Jul 23, 2004
    385
    +10
    I'm debating importing one of these from the US, as it will be significantly cheaper.
    Am I likely to have any problems with recording or playback ?
    thanks
    DT
  2. shoehorn
    shoehorn
    Jul 2, 2003
    1,649
    The Garden of England
    +41
    I don't think there will be problems.... don't know for sure though...
    You can change between PAL and NTSC very easily for output at any rate...
    Maybe ask Archos directly, or scan the manual...
    Support
    Manual
    I'd guess the only "problem" is if there is a hardware issue it will be harder to sort out.
  3. BHL70
    BHL70
    You shouldn't have a problem as they are basically the same unit. It will even come with the European .pdf manual on it.
    just make sure your TV can take an NTSC signal or when/if you record an NSTC signal record it as PAL.
    I bought one inthe US and the only problem I had was getting Archos to receive an input signal from my Sky (Pace) Digibox.
    I ended up purchasing a scart to S-vhs, composite and audio lead, the lead is also switchable. The scart adapters supplied with the Archos are not very good.
    Good luck
    Brian
  4. davet010
    davet010
    Jul 23, 2004
    385
    +10
    Decided to get one over here anyway.
    Been playing with it a little, but having problems with some of the video files. Does anyone know how (or if) I can convert an .mpg file to .avi ?
    thanks
  5. burnrubber
    burnrubber
    Feb 19, 2005
    263
    +8
    For BHL70, see that you bought one of these form the U.S I am off to Florida in June as was wondering were I can get one from (AV4100)
    Thanks in advance
  6. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    Is there anyhing with this that I can buy that allows me to listen to mp3's through a radio, like an iTrip does for an iPod.
  7. Maff et1
    Maff et1
    Belkin do a fm transmitter: http://www.blueunplugged.com/Products/TuneCast_II_Mobile_FM_Transmitter__Black.aspx
    Not used it myself but belkin tend to be ok (sound quality is never great on these things anyway).
    However if you plan to use this in the UK I think you need a broadcasting licence and an officially designated frequency as the laws don't take into account broadcast power. http://www.ofcom.org.uk/radiocomms/ifi/enforcement/rtandthelaw?a=87101 - have a look at the section on 'Short Range Radio Devices / FM Modulators'
  8. Donnacha
    Donnacha
    Jul 4, 2002
    8,531
    York
    +4,652
    I've got the AV420, and I use tools like DrDivx to turn Mpeg and DVDs into DIVX files that are compatible on the AV420, which I assume is similar to yours, just a smaller hard drive.
    Also try PocketDivxEncoder - its free
  9. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    Besides the capacity, what's the difference between the AV4100 nad the AV 380?
