Archos 605 not recognised by computer
Discussion in 'Video Streaming Boxes & Services' started by Tiff, Feb 6, 2009.
  1. Tiff
    Tiff
    I have an archos 605 80gb wifi new at Xmas and has been working fine with Vista and then suddenly the computer does not recognise it's existence. I have tried reset, I have checked the firmware, I have checked the USB ports and I have made sure I have the latest windows media player but no joy. It works fine and charges fine on the dock but will simply not appear when I plug it into the USB on either my PC or laptop. I would really appreciate some help with this as I have done everything I can think of!
  2. JJMcClure
    JJMcClure
    Dec 15, 2008
    16
    Is the 605 blank when u plug it in, or does it have the USB or charge message?
  3. Tiff
    Tiff
    Thanks for responding.
    No, the Archos ordinary screen comes on as though it is not plugged in to anything, and it works perfectly. When I plug the usb cable in nothing changes, there is still the main screen and no'enable' usb.
  4. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    That sounds like a faulty cable.
    If you have one of the docks try connecting the dock to the computer using a standard USB cable.
  5. priyaent
    priyaent
    May 9, 2008
    2
    I have the same problem.the computer does not recognise it's existence. I have tried reset but the problem is still the same. if the USB cable is faulty why its charges properly??? i had restore factory settings 2 times. plz any body solve my problem. and plz tell me where is service center of archos in mumbai( india)?
